If you are not concerned about "correctness", switching to rubber housed 6 volt seal beam tractor headlamps will give noticeably improved illumination over original lights. These lamps run about $25 apiece at Tisco, etc.
However as Jim points out the stock generator can safely power a maximum of only 3 lights - and then only when the engine is running at full RPM.
Unfortunately there is no way to safely boost the output of your stock generator beyond about 15 amps without the risk of burning it out.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
