Posted by keithg on August 26, 2011 at 10:27:55 from (173.19.48.79):
I had removed the belly pump, clutch and short shaft between the clutch and front transmission coupler of a 47 M so I could replace bearings and seals on the transmission countershaft and upper shaft.
I see the flywheel surface has small cracks and it appears the rear crankshaft seal is leaking. As I understand, the tractor will need to be split to remove flywheel for machining and also to fix the seal -- Is that correct?
It may be a while before splitting, so I am considering putting the clutch, drive shaft and belly pump back in the tractor now. Assume I would put in a new throw out bearing now.
Can you split the tractor and get it back together with the belly pump installed? Or do you guys remove the pump for better access? Thanks.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
