Posted by LarryT on August 27, 2011 at 14:30:46 from (174.56.65.35):
Ok, Lets take it from the top. Was having intermittent trouble getting it to engage reverse. Re-adjusted the linkage on the clutch and transmission brake. Problem has gradually gotten worse. This morning would only go in 1 out of 20 attempts. Remo9ved top of transmission. Nothing obvious except just a little slack in the reverse cam and arm assembly where it penetrates the cover. Then there is a very small amount of slack movement in the cam roller its self. I measured the diameter of the pin that engages the fork and it is .375" and the fork is .379". I then pulled the side cover and noticed some slight slack between the reverse shift fork and the ring. Again just a little slack in the pads. I am wondering if these small amounts of slack could combine to keep the reverse from engaging? Now, what can I do to take the slack in pivot shaft that goes through the top cover? Does anyone know if these parts are available. Does anyone know any determinant long term fixes? My mind is wide open and so is my gearbox. Time is of the essence. Thanks, LarryT
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
