Re: 1206 Transmission Reverse Problem Please HELP!!!
Posted by Owen Aaland on August 27, 2011 at 15:28:54 from (216.47.33.176):
In Reply to: 1206 Transmission Reverse Problem Please HELP!!! posted by LarryT on August 27, 2011 at 14:30:46:
The wear on the cover and the shaft going through it are the most likely causes for your problems. Rebuilt covers are available through AG Parts, Hy-Capacity, and probably others. The other linkage parts are also available in the after market.
A rebuilt cover is actually better than a new on because the holes will be bored inn the correct locations and steel bushings installed. The bushings are longer than the original hole through the cover and will not wear as rapidly as the original cast iron.
