1949 H hydraulics
Posted by L. M. Reese on August 28, 2011 at 17:04:48 from (64.18.99.152):
I just bought an H and hooked it up to my NH 472 haybine and tried to lift the cutter head up with the tractors liftall hydraulic system and nothing. The tractor won't lift the haybine. The 472 is a 7' mower conditioner and has a 2x8 cylinder and I would think the H shouldn't have any problem lifting it. I put a test guage on the tractor's hydraulic outlet and it puts out about 800 psi. Does anybody have any expierance using an H with a haybine? Are the factory hydraulics not strong enough to lift this little mower? or is there something wrong with the pump?
