F12F14 Owners
Posted by James Williams on August 28, 2011 at 20:05:38 from (98.218.168.38):
Several years ago I had trouble not getting enough gas to the carb to start my F14,so I built up the fuel pump rod and seemed it fixed the problem.This tractor has never started easy.Tonight I went to start it and it would try to start but would not keep running.I have a cut off valve installed in the line going to the carb,Thinking the carb was flooding I turned the valve off,and as soon as I did the motor started,this has happened twice.Im going to redo the pump rod,is there any way to tell if you have the correct amount of gas.
