Re: adjust touch controls
Posted by farmall400 on August 29, 2011 at 04:37:43 from (67.142.164.35):
In Reply to: adjust touch controls posted by realolman on August 29, 2011 at 03:22:57:
Sounds like you might have double acting cylinders and your valves
set for single acting or single acting on double setting.Take the rt
hood panel off and look at valve ther is a pin pointing to a d or s
on each valve section it is crossways on a shaft with flats so you
can put a wrench on it and switch back and forth. we had to do it
every year when we put the picker on and off. If that is set to match
your cylinders you have a detent problem inside the valve. hope
that helps. Scottz
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
