Re: adjust touch controls
Posted by realolman on August 29, 2011 at 17:15:02 from (108.22.70.94):
In Reply to: adjust touch controls posted by farmall400 on August 29, 2011 at 04:37:43:
farmall400 said: (quoted from post at 04:37:43 08/29/11) Sounds like you might have double acting cylinders and your valves
set for single acting or single acting on double setting.Take the rt
hood panel off and look at valve ther is a pin pointing to a d or s
on each valve section it is crossways on a shaft with flats so you
can put a wrench on it and switch back and forth. we had to do it
every year when we put the picker on and off. If that is set to match
your cylinders you have a detent problem inside the valve. hope
that helps. Scottz
it will raise the tractor off the ground with down pressure.... does that indicate anything?
it seems like it's the hydraulic pressure itself doing it.
This post was edited by realolman at 17:23:08 08/29/11.
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
