Re: adjust touch controls
Posted by farmall400 on August 29, 2011 at 20:18:06 from (67.142.164.24):
In Reply to: adjust touch controls posted by realolman on August 29, 2011 at 03:22:57:
If you have down pressure that means you definetly have 2 way or
double acting cylinders. that is 2 diferent names for same thing.
could still be valve set wrong or the internal detent that is
supposed to stop the control handle. you may have to take end
covers off spools. Does it do this on all circuits? sz
