Re: adjust touch controls
Posted by realolman on August 30, 2011 at 03:11:37 from (108.22.70.94):
In Reply to: adjust touch controls posted by farmall400 on August 29, 2011 at 20:18:06:
farmall400 said: (quoted from post at 20:18:06 08/29/11) If you have down pressure that means you definetly have 2 way or
double acting cylinders. that is 2 diferent names for same thing.
could still be valve set wrong or the internal detent that is
supposed to stop the control handle. you may have to take end
covers off spools. Does it do this on all circuits? sz
I only use one circuit... for the front end loader. the rear end works ok.... at least as far as I know. I'll have to check out the valve... thank you
This post was edited by realolman at 03:13:02 08/30/11.
