Re: Farmall M problems still
Posted by Janicholson on September 01, 2011 at 19:51:51 from (96.24.99.126):
In Reply to: Farmall M problems still posted by tripleccattleco on September 01, 2011 at 19:11:40:
There are few things harder to diagnose on line than what appear to be fuel system issues. I need to be certain of one issue. In your post above you indicate that it idles with the choke closed. In normal terms, closing the choke is a starting procedure that actually blocks the air intake richening the mix radically. If it runs after starting with the choke closed (rod pulled out toward the driver), there is something very wrong, the tractor should idle and run with the choke open. Rod pushed in!!
Help us on that issue first, as all answers depend on clarification. Jim
