Farmall M problems still
Posted by tripleccattleco on September 01, 2011 at 19:11:40 from (97.195.198.58):
I posted last week about some problems I was having with
my M.The tractor would idle fine but when you started pulling
the throttle back it would die. The tractor would not rev up at
all. Several of you said the main jet was possibly dirty. I
soaked the carb in carb cleaner overnight and blew
everything out with the air compressor. I put it back on, this
time, it will idle just like before, with the choke closed. I
opened the choke very slightly and it reved up to about half
throttle, it will still not rev up with the throttle lever, if I open
the choke all the way it idles back down and runs a little
rougher. I did check the fuel level in the carb and it is at the
correct level. I would appreciate any advice I can get! I can
also be reached at 573-718-0261. I'm getting very frustrated
with this, the local guys all have newer tractors and aren't
much help. Thanks! Chris
