Re: Farmall M problems still
Posted by Brownie 450 on September 02, 2011 at 05:09:09 from (66.43.241.198):
In Reply to: Farmall M problems still posted by tripleccattleco on September 01, 2011 at 19:11:40:
I'm wondering here if the carb hasn't been apart before you got the tractor?? If the person who worked on it previously hadn't put the venturi air horn or something similar back in when working on it, that could cause all sorts of problems. The best thing at this point would be putting a known good carb on & see if it performed correctly. If the same symptoms were evident, it would have to be problems with holes in the manifold or intake gaskets not sealing, or------. Not the carb.
