Re: Farmall M problems still
Posted by mkirsch on September 02, 2011 at 05:17:40 from (64.80.110.75):
In Reply to: Farmall M problems still posted by tripleccattleco on September 01, 2011 at 19:11:40:
That only works if you have another M with a known-working carb on it sitting around... Or, I suppose you can buy a rebuilt carburetor but that's a big chunk of change, and they usually get banged around during shipment and need to be taken apart and fixed before you can use them.
The easiest thing now is to try the propane trick and look for a manifold leak. You should not notice a change in how the tractor runs as you run the unlit torch around the manifold. Don't worry, you will NOT "blow up." The engine fan blows the excess propane away before it can build up to explosive levels.
Next, disconnect the fuel line from the carburetor and check for fuel flow. It should run a full strong stream of gasoline out of the fuel line.
If both those tests pass, you need to take the carburetor apart, do a REAL cleaning, and install a carburetor kit in it.
