Posted by Harold Hubbard on September 02, 2011 at 05:34:32 from (205.209.16.24):
In Reply to: Farmall M problems still posted by tripleccattleco on September 01, 2011 at 19:11:40:
You can check for manifold leaks by spraying WD-40, carb cleaner, propane, or something like that along the gasket area. Plain motor oil will work, as it is thick enough to partially plug any leaks. Even if the material is non-flammable it will change the air fuel mix as it is pulled into the crack. DO NOT use ether.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
