Re: How to run hyd pump off of crank pulley?
Posted by gene bender on September 03, 2011 at 04:43:06 from (67.55.226.76):
In Reply to: How to run hyd pump off of crank pulley? posted by CenTex Farmall on September 02, 2011 at 07:18:48:
You are going to run the pump backwards better check the pump to see if it will operate backwards if you mount it out the front hooked to the crank.
