Re: Trying to Free a Stuck Engine (Got a Question for Old)
Posted by old on September 04, 2011 at 19:33:15 from (209.86.226.11):
In Reply to: Trying to Free a Stuck Engine (Got a Question for Old) posted by RTR on September 04, 2011 at 19:25:07:
First off are the cylinders dry as in NO water in them??? If they are dry and your sure they are fill them with AFT and let it sit. Now i it has so much as one drop of water in any of them mix half a bottle of rubbing alcohol with 2 qts or ATF and use that to fill the cylinder. The rubbing alcohol will absorb the water and then the ATF can do its job. Check it every day and if you can do so with the starter and a 12 volt battery. Only use short fast taps on the starter button and always with the plugs out but always put them back in when your not messing with it
