Re: Lubricating clutch bearing?
Posted by Bob on September 04, 2011 at 20:58:43 from (64.255.159.192):
In Reply to: Lubricating clutch bearing? posted by PaulW_NJ on September 04, 2011 at 20:47:49:
REPLACE the TO bearing, for about $30, as the washing you've done has probably washed dirt/grit INTO it.
If you INSIST on taking the risk of it failing and having to split the tractor AGAIN, you can put the bearing and a gob of grease in a little metal pot and CAREFULLY heat it up. When the grease is liquid, SOME of it will find it's way into the bearing.
This post was edited by Bob at 21:00:13 09/04/11.
