Posted by PaulW_NJ on September 04, 2011 at 20:47:49 from (74.105.14.16):
Finally putting my 240U back together after rebuilding the engine,and I'd like to reuse the throw-out bearing. Turns freely, tight, looks fine. I cleaned it up real well with kerosene when I took it apart, and feel it should get new grease. However, that doesn't look possible to do?
Even if I press bearing off of housing (does it press off?) I don't think that will provide a way to get grease in will it? The fitting on the housing is for the shaft, but there is a small hole that looks thru to the bearing . . just don't see an easy way in there . . .
any suggestions? hate to replace it if I don't need to
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
