Re: Trans Front roller bearing W4
Posted by Zachary Hoyt on September 05, 2011 at 04:41:05 from (173.86.124.29):
In Reply to: Trans Front roller bearing W4 posted by Robert F on September 04, 2011 at 20:02:37:
The H has a pilot bearing on the front end of the main shaft and the rollers do ride directly in the inside of the constant mesh gear. I do not know if the w4 is the same. H has a bolt and a cupped washer, not sure if that is the right term but I think you'll see what I mean.
Zach
