I went out and started the tractor up and ran at 3/4 throttle. With everything hooked up (no wires removed), I hooked a jumper wire with alligator clips to the FEILD terminal on the generator, and the other end to the upper generator bracket for a ground. When I did the ammeter jumped up to around 10-11 on the charging (+) side. We thought maybe it was a ground issue. I unhooked the left screw that holds the regulator on, and scratched the surface well with a screwdriver and replaced it. Still no change. It charges only with jumper wire. Then I decided to replace the regulator with a brand new one I had on hand. After replacing the regulator, stil lthe same thing. It only charges with the jumper wire.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
