Re: Genny Discharging on Cub (tried almost everything) - ...
Posted by Janicholson on September 05, 2011 at 18:21:19 from (96.24.99.126):
In Reply to: Re: Genny Discharging on Cub (tried almost everything) - ... posted by RTR on September 05, 2011 at 11:53:28:
The new voltage regulator will not charge an 8volt battery. It is set for 7.2 or so. When it sees an 8.4 volt source (charged 8 volt), it realizes it has no business charging. To make it work, it will be necessary to adjust the voltage relay spring so it is tighter, this holds the contacts together harder, making more voltage.
Doing this also runs all parts of the electrical system at ablut 9 volts. It is hard on the points and coil. it burns lights brighter, but shortens their life to about 1/2 normal or so.
It also rund more current through the field coils heating the gen more than normal.
None of these things are forbiden, but that little cub needs a 6 volt battery. You now know it can charge, (gen good) and with a 6v it will do so as is. Jim
