H Block plate leak
Posted by David G on September 05, 2011 at 15:48:22 from (75.221.17.198):
The new block cover plate leaks on the H. I believe the new plate is so thin that the bolts do not pull the area between them tight enough.
I am going to pul it and put a nice bead of permatex on it.
That appears to be the only issue with the conversion.
