Posted by Mike1972chev on September 05, 2011 at 17:06:58 from (99.50.230.189):
In Reply to: H Block plate leak posted by David G on September 05, 2011 at 15:48:22:
That is a good point soybeanjoe.
If you take the plate back off,flip it over and check the holes that the bolts pass thru.If they ARE NOT flush with the sealing surface,they need to be made that way !!!!! with the sealing surface STILL face up,take a small hammer(ball peen)to the bolt holes,backing the holes up on the botton side with a small socket not much bigger than the bolt holes.(A piece of small pipe or tubing works well,also.)
Gently tap the holes flush with the sealing surface.(stamped automatic transmission pans have this same issue ALOT !!!! Like on a Turbo 350)
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
