Posted by Rick MacGregor on September 05, 2011 at 17:47:43 from (4.157.62.80):
Pete, thanks for the tip, that worked perfect. I had an old hard-wood broom handle that I shortened and used as a drift punch. One more question, the manual does not seem to go over removal of the T/A. It appears that the clutch disc is frozen to the shaft, is that possible? The book does says to use 3 small bolts to keep the T/A clutch compressed, but would that prevent the T/A from sliding out? Thanks in advance! Rick.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
