Re: Carb kit
Posted by rustyfarmall on September 06, 2011 at 12:53:59 from (216.248.71.224):
In Reply to: Carb kit posted by bornred on September 06, 2011 at 10:32:49:
That kit from NAPA won't have all the parts you need, but $175 from Case-IH is just crazy. I suggest you buy a basic gasket set with needle and seat for a Farmall M, or if you already know you need a new throttle shaft, buy the complete kit for an M. The choke shaft in the M kit will be wrong for the Super M, but everything else will be the same. If you need a new choke shaft, Case-IH is the only place to get it. None of the aftermarket kits have that shaft.
