Posted by David G on September 06, 2011 at 18:53:49 from (72.101.63.161):
In Reply to: FarmAll H posted by Dean Trent on September 06, 2011 at 17:38:43:
If I remember right, the slotted end shaft screws out of the inner shaft. It is larger than the seal, which is on the inner shaft. Put the tractor in gear, pull coil wire for safety, then put a slotted bar in the groove and screw out. It is right hand thread, so left to loose.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
