Re: FarmAll H
Posted by Janicholson on September 06, 2011 at 20:44:34 from (67.72.98.45):
In Reply to: Re: FarmAll H posted by David G on September 06, 2011 at 18:53:49:
Exactly correct! It is really tight, a 1/2 inch square bar placed into the slot, and about 3' long when pushed with your feet (trans in High gear, brakes on or wheels blocked) will be an expected mode! Jim
