Farmall / PTO Drve shaft cage
Posted by Rick MacGregor on September 07, 2011 at 04:50:51 from (208.105.148.138):
Thanks for all the tips guys! Finally figured out what is causing all my grief. IT Manual calls it the PTO drive shaft cage, it bolts on inside the front of the bell-housing. It needs to be removed so that the T/A can be removed. Tapping it back & forth and up & down, appears to be loosening a bit, but I want to make sure that"s not going to damage anything. Also, someone had it apart before, and did not have it seated correctly when it was put back together. They cranked down on the bolts and put small cracks in two of the "ears", so that may be affecting why it is coming apart so hard. There is very little room on the opposite side to punch against, due to the angle. Anyone have some tips on this?
