Shop Manual
Posted by scatter on September 08, 2011 at 11:33:52 from (67.142.168.20):
Hi, I"ve got a 1941 A. It has a couple of leaks I need to fix. One is the front crankshaft seal, and the other is where the drive shaft goes into the transmission gearbox. A friend showed me his method of getting the crankshaft pulley off. But I would like a good, detailed manual to help me along. I have an IT manual that as far as I"m concerned is good for starting a fire and that"s about it. Is there anything printed that is detailed like a haynes manual is for automobiles?
