Re: Clutch acting strange...Help
Posted by Goodman on September 09, 2011 at 09:03:08 from (208.61.228.130):
In Reply to: Re: Clutch acting strange...Help posted by Mike1972chev on September 09, 2011 at 07:15:22:
No, I didn't have it rebuilt but I'm sure it is a reman.
Put all new clutch disk, and pressure plate, throw-out bearing, etc.
I have adjusted linkage both ways. Right now it is catching right at the top, that should give me the most clearance when depressed fully, but still won't clear. That tells me it isn't the linkage.
The fingers sounds like a possible option, Can I check them in some way and adjust them on the tractor from the access hole?
