Did you have the clutch that came out of it rebuilt???
I have seen them remanufactured with the release fingers uneven on the pressure plate.Also,like previous post,disc warped,or even clutch linkage worn/out of adjustment enough as to not FULLY release clutch.(Disc is still slightly dragging when pedal is fully down)You NEVER will get it to go in gear if that disc is even catching a little !!!!
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
