If the shaft increases speed with the clutch pedal in is likely dragging in the pilot bearing bushing. With it in gear and the tractor stopped it is unable turn the shaft and engaged gears with the clutch in. But this could account for some of the trouble stopping. If that is the cause, you have to split and replace the bushing-CaseIH still has them, you need a puller to get the old one out, or you can carefully cut it out. I have replaced two, pulled out the first in about 10 seconds, the second had to be cut out. Grease the bushing liberally. Also examine the shaft and file off any rough places. You can rent/buy a puller at O'Reilly's.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
