Clutch acting strange...Help
Posted by Goodman on September 09, 2011 at 05:31:32 from (208.61.228.130):
Man things are getting close to finally finishing Super A restoration. Actually drove her around yesterday, first time it has moved under it's own power in 15 years.
I installed a new clutch, plate, etc but am having trouble with it releasing. I can start it in gear, clutch depressed, and the tractor never moves, the clutch is adjusted pretty well, have the right free play,etc. But once moving if I just push in the clutch I'm getting "some" forward movement from the engine. Without the brakes it will take it 15-20' to wind down. With clutch in, tractor running, if I take it out of gear there is no chance of putting it back without shutting it off. Within 2 seconds of taking out of gear you hear the transmission shaft pick up speed.
The only thing that touches that shaft is the point where it goes in the pilot bearing in the crankcase. Can there be enough friction there to cause this?
I can't figure this one out???????
