2404 clutch problem.
Posted by tempola on September 13, 2011 at 19:11:49 from (75.121.248.197):
The clutch has a new disc, and I am certain that it's installed the right way. The tractor has set a very long time. the throwout bearing is also new.
when you let the clutch out, it chatters bad. if you push the pedal down, it might release, or just chatter, and keep pulling. ive adjusted it every which way, no improvement.
Im suspecting the old pressure plate may be warped....what do you guys think? ive looked at it up through the hole, and the bearing is engaging, and operating the clutch.....
AT
