Re: 2404 clutch problem.
Posted by Janicholson on September 14, 2011 at 18:56:29 from (96.24.99.126):
In Reply to: 2404 clutch problem. posted by tempola on September 13, 2011 at 19:11:49:
Make sure the fingers are identical in clearance on the T/O bearing. Adjust to get even. Use it some and put it under a few stressed starts (3 high gear starts within 2 minutes) Jim
