Posted by Janicholson on September 14, 2011 at 07:52:35 from (199.17.6.115):
In Reply to: Super A to 12 volt posted by David Lampman on September 13, 2011 at 22:50:18:
A Delco SI12 series putting out 80 or more amps will do what you need. Put Bob M wiring on it (dont use a one wire system the 3 wire is very easy. Because ofthe winch the 12 series is needed, If no winch, a Hitachi from an 88 nissan PU is smaller and wires the same. Jim
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
