Re: 806 - 1206 pistons difference???
Posted by karl f on September 16, 2011 at 15:21:08 from (209.188.106.138):
In Reply to: Re: 806 - 1206 pistons difference??? posted by Owen Aaland on September 16, 2011 at 14:36:42:
less compression in a turbo engine makes it easier
to prevent detonation and other high cylinder temp
problems. It sacrifices maximum power for
simplicity and reliability. Cost reduction in
research and development too. High compression,
higher turbo pressures often require more complex
fuel and air controls that monitor and change the
air and fuel real time based on various sensor
inputs. A wastegate and modern computer control
(or many mechanical devices) are definitely
required when you get into higher manifold
pressures and higher compression. My info is
based on conversations with a guy that was
modifying the heck out of his turbo car.
karl f
