Re: 806 - 1206 pistons difference???
Posted by Owen Aaland on September 16, 2011 at 14:36:42 from (216.47.32.147):
In Reply to: 806 - 1206 pistons difference??? posted by Larry B 1486 on September 16, 2011 at 14:08:10:
With everything other than the pistons being the same the change in compression has the result of a larger combustion chamber. With a turbocharger the dynamics change a bit compared to a naturally aspirated engine. In the 806 the amount of air entering the cylinder (ignoring any outside restriction) is dependent on the displacement of the engine. With a turbocharger the lower compression will allow more air to be pumped in at the same boost pressure.
If the differences in compression ratio are enough to make a noticeable difference in power I don't have a clue.
