I didn't know there was a difference in pistons. Good to know for the future. (I'm sure I'll have to overhaul the 806 eventually.)
A lower compression ratio would allow for higher boost pressures to be ran, which would result in more power and cooler EGT's. It's why my old chevy 6.5 supposedly only runs 5-8 lbs boost. I don't have a gauge on it. It has 22 to 1 pistons in it. Later ones and all your 7.3's and 5.9's are at 17 to 1 (Give or take) and run 15-20 lbs boost.
My best understanding is that with a turbo engine, a little lower compression and lots more boost pressure is beneficial rather than the other way around. More potential pressure would also allow the turbo to better adjust for altitude changes, too. Of course, a stock engine running stock rpm's can only support so big of a turbo...
Neat conversation. I hope my understanding is pretty close. If not, I'd like to be set straight. -Andy
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
