806 - 1206 pistons difference???
Posted by Larry B 1486 on September 16, 2011 at 14:08:10 from (173.190.60.113):
Wanting to do a overhaul on the DT 361 motor. Was looking a piston sets and it list different pistons for a 1206 than a 806. Said 1206 has a lower comperssion piston than the 806. The 856,1256,1456 with a 407 uses the same pistons. What happens if you put 806 pistons in a 1206? They all use the same head so whats with a lower compression in a 1206? To me that should be the other way around. If you put 806 pistons in a 1206 motor won't it give more power?
