I put 1206 pistons in my 806 when I o.h. it. It was recommended by a friend that has worked on several of these engines. Not sure I notice a difference, because it was tired before I took it apart. If you do change pistons you may have to check the injectors, the 1206 takes a little more pressure if memory serves me correctly. I had mine all shimmed a little and had to have one rebuilt at the time
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
