Posted by rustred on September 17, 2011 at 12:46:56 from (74.200.18.156):
In Reply to: 560G Timing help posted by matt_in_michigan on September 17, 2011 at 12:03:22:
yes on crankshaft pully.get #1 cyl. on compression and line up to 2 degree mark on pulley with pointer on timing cover.in stall rotor to #1 firing position on cap.turn key on and when you hear it spark as turning dist in opposite direction of rotation, thats exactly where you tighten it down.make sure your on the compression stroke though, you can tell by placing thumb over hole as cranking, it will be pushing compression out.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
