Posted by matt_in_michigan on September 18, 2011 at 12:18:20 from (208.53.122.83):
In Reply to: Re: 560G Timing help posted by rustred on September 17, 2011 at 12:46:56:
For some reason, even though I'm pretty good with a computer, I still can't figure out how to load a GD picture into a post. I gave up, and posted them in the community section under 560 timing.
Anyhow, here's the links to the 2 pics. 2 degrees on the A side of TC (or DC), or the R side (couldn't remember what it was marked, and couldn't make it out in the pic)? I assume the A is for advance, and the R is for retard?
Is there an easy way to hand crank the engine to 2 degrees? It's a real pain w/o a helper.
Basically though, once that finger is aligned with the 2 degree mark, all I need to do is align the distributor so that the rotor is sitting underneath the #1 wire?
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
