Re: Project 560 continues....
Posted by CNKS on September 17, 2011 at 18:53:37 from (216.144.104.128):
In Reply to: Re: Project 560 continues.... posted by colby64 on September 17, 2011 at 18:33:35:
I mentioned the weights. To get the cast smooth you have to use repeated applications of body filler, sanding and repeating, and a lot of surfacer and sanding. If you don't do it all perfectly, the defects will be highlighted. To me it is ridiculous to do that much work, but it is your tractor. Some people are opposed to using automotive paints -- this carries it much further than that. I might occasionally fix a noticeable defect in the cast, that is all. It will look fine if you take care of the non-cast parts, get all the dents out and get them perfectly smooth before painting.
