Posted by Brownie 450 on September 18, 2011 at 13:45:07 from (66.43.241.198):
In Reply to: 1940 Farmall A posted by rhill-co on September 17, 2011 at 18:43:15:
Is any damage visible to the new cap or rotor? Is the rotor firing tip turned to the side? Did you have the "gears" apart back where the rotor engages the dist shaft? If so, are they in time? Our A had the gears jump teeth one time, & the rotor would fire just as you describe. Worth a look.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
