Re: 1940 Farmall A
Posted by rhill-co on September 18, 2011 at 19:21:07 from (71.208.99.175):
In Reply to: Re: 1940 Farmall A posted by Brownie 450 on September 18, 2011 at 13:45:07:
Thanks for all the help. Timing was all ok. Wires cw in the correct order. Saw no issues with the new cap or rotor. Shimmed the rotor to fit tighter to the shaft. just used aluminum duct tape. Just right. But nothing corrected issue. Mag was firing out the coil each hit and firing our terminal 1 and 4. (180deg from each other) but would not fire on the opposite terminals. Tested the condenser, it was dead. put in an new condenser and now firing on all four terminals. Thanks, Rick
