Re: Super A Head Gasket Question
Posted by gene bender on September 18, 2011 at 17:32:59 from (207.177.56.78):
In Reply to: Super A Head Gasket Question posted by mark (PA) on September 18, 2011 at 17:21:36:
Better pull the manifold off and take a long hard look at the openings in the head some rust out and let water out thru the exhaust as there is coolant close to the exhaust ports and the head is ate away in those areas and will let coolant out thru the exhaust ports ive had it happen to me and have seen others the same way so i would pull the manifold and look for a hole in the head in the exhaust port letting some coolant out into the exhaust port sure makes smoke.
