Hi Jim.Yes it seems to be a common issue.I found two other people in the area with 434 's and have the same symptoms as this one.(they have never got it looked at.)Will keep asking around.Heading to a repair shop on Thursday and will hopefully learn something about which valve I should be looking at.The biggest problem I have run into so far is that most of the guy's working on tractors in the area are to young to know anything about these.In the meantime hopefully someone out there might know.Will post if I make any progress. Thanks again, John
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
