John, I believe you are correct that the main lift cylinder is not leaking or the 3pt would go down with shut off valve closed. We had a 434 (newer version of B414) do the same thing with load on 3pt but it would stop with draft control fully forward. Also would stop with shut off valve closed. The other thing was it would not occur as much if the Slow/Fast valve was in slow position. Never did find the problem and traded it after about 10 years on a 384.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
